Hello! Recently, I have been following this tutorial:
    I just saw this super cool video from @Oswaldo_Hernandez  on Linkedin show a proof of concept of a web app using Speckle and ChatGPT.
Check it out!
And I found KeyError: ‘parameter’ which I believe comes from this line which used to select the parameter from a category.
parameters = commit_data[selected_category][0][“parameters”].get_dynamic_member_names()
Is there something wrong with the code?
I really appreciate any help you can provide.
                teocomi
                (Matteo Cominetti)
                    15 April 2024 07:29
              2
              The way categories are defined has changed a bit over time, you can inspect your specific data structure from the scene explorer on our viewer page.
Alternatively, if you post a link to your model we can have a look!
I suspect it has to do with: BREAKING CHANGE: Introducing Collections Class for Predictable Data Hierarchies: Testing the Revit Connector
              Hello! thank you for your response. I am trying to edit the code based on the new structure, and it works!
I am using the exact model from the repo and edit the line:
parameters = commit_data.getitem (selected_category)[0][“parameters”].get_dynamic_member_names()
