Hello, Speckle Community,
I’ve been working with self deployed Speckle Server and facing some challenges when dealing with large IFC file uploads and imports using the file import service package within a Docker setup. I hope to find guidance or solutions from the community regarding these issues. Below are the details of the problems I’ve encountered:
following is the docker compose file I’m using
version: '2.3'
services:
# Speckle Server dependencies
postgres:
image: 'postgres:14.5-alpine'
restart: always
environment:
POSTGRES_DB: speckle
POSTGRES_USER: speckle
POSTGRES_PASSWORD: speckle
volumes:
- postgres-data:/var/lib/postgresql/data/
healthcheck:
# the -U user has to match the POSTGRES_USER value
test: ["CMD-SHELL", "pg_isready -U speckle"]
interval: 5s
timeout: 5s
retries: 30
redis:
image: 'redis:7-alpine'
restart: always
volumes:
- redis-data:/data
ports:
- '127.0.0.1:6379:6379'
healthcheck:
test: [ "CMD", "redis-cli", "--raw", "incr", "ping" ]
interval: 5s
timeout: 5s
retries: 30
minio:
image: 'minio/minio'
command: server /data --console-address ":9001"
restart: always
volumes:
- minio-data:/data
healthcheck:
test: ["CMD", "mc", "ready", "local"]
interval: 5s
timeout: 5s
retries: 5
# Speckle Server
speckle-ingress:
image: speckle/speckle-docker-compose-ingress:latest
restart: always
ports: []
environment:
FILE_SIZE_LIMIT_MB: '2000'
NGINX_ENVSUBST_OUTPUT_DIR: '/etc/nginx'
labels:
- "traefik.enable=true"
#TODO: replace `example.com` with your domain. This should just be the domain, and do not include the protocol (http/https).
- "traefik.http.routers.speckle-ingress.rule=Host(`speckle.schullerco.net`)"
- "traefik.http.routers.speckle-ingress.entrypoints=websecure"
- "traefik.http.routers.speckle-ingress.tls.certresolver=myresolver"
- "traefik.http.services.speckle-ingress.loadbalancer.server.port=8080"
speckle-frontend-2:
image: speckle/speckle-frontend-2:latest
restart: always
environment:
NUXT_PUBLIC_SERVER_NAME: 'local'
# TODO: Change NUXT_PUBLIC_API_ORIGIN to the URL of the speckle server, as accessed from the network. This is the same value as should be used for the CANONICAL_URL in the server section below.
NUXT_PUBLIC_API_ORIGIN: 'https://speckle.schullerco.net'
NUXT_PUBLIC_BACKEND_API_ORIGIN: 'http://speckle-server:3000'
speckle-server:
image: speckle/speckle-server:latest
restart: always
healthcheck:
test: ["CMD", "node", "-e", "try { require('node:http').request({headers: {'Content-Type': 'application/json'}, port:3000, hostname:'127.0.0.1', path:'/graphql?query={serverInfo{version}}', method: 'GET', timeout: 2000 }, (res) => { body = ''; res.on('data', (chunk) => {body += chunk;}); res.on('end', () => {process.exit(res.statusCode != 200 || body.toLowerCase().includes('error'));}); }).end(); } catch { process.exit(1); }"]
interval: 10s
timeout: 3s
retries: 30
depends_on:
postgres:
condition: service_healthy
redis:
minio:
environment:
CANONICAL_URL: 'https://speckle.schullerco.net'
SPECKLE_AUTOMATE_URL: 'https://speckle.schullerco.net:3030'
REDIS_URL: 'redis://redis'
S3_ENDPOINT: 'http://minio:9000'
S3_ACCESS_KEY: 'minioadmin'
S3_SECRET_KEY: 'minioadmin'
S3_BUCKET: 'speckle-server'
S3_CREATE_BUCKET: 'true'
FILE_SIZE_LIMIT_MB: 2000
# TODO: Change this to a unique secret for this server
SESSION_SECRET: 'MyS3cureSess!onKey12345'
STRATEGY_LOCAL: 'true'
DEBUG: 'speckle:*'
POSTGRES_URL: 'postgres'
POSTGRES_USER: 'speckle'
POSTGRES_PASSWORD: 'speckle'
POSTGRES_DB: 'speckle'
ENABLE_MP: 'false'
USE_FRONTEND_2: 'true'
FRONTEND_ORIGIN: 'https://speckle.schullerco.net'
reverse-proxy:
image: traefik:v2.10
command:
- "--providers.docker=true"
- "--providers.docker.exposedbydefault=false"
- "--entrypoints.websecure.address=:443"
- "--certificatesresolvers.myresolver.acme.tlschallenge=true"
# To use Let's Encrypt staging server instead of production, uncomment the following line
#- "--certificatesresolvers.myresolver.acme.caserver=https://acme-staging-v02.api.letsencrypt.org/directory"
# TODO: replace `{[email protected]}` with your actual email
- "--certificatesresolvers.myresolver.acme.email=vaddivamsi524@gmail.com"
- "--certificatesresolvers.myresolver.acme.storage=/letsencrypt/acme.json"
# To enable the Traefik web UI (enabled by --api.insecure=true); this is not recommended as it will expose the Traefik dashboard to the internet
#- "--api.insecure=true"
ports:
# The HTTPS port (required for Traefik to listen to HTTPS requests)
- "443:443"
# The Traefik Web UI port if enabled by --api.insecure=true
- "8080:8080"
volumes:
- "./letsencrypt:/letsencrypt"
# So that Traefik can listen to the Docker events
- "/var/run/docker.sock:/var/run/docker.sock:ro"
preview-service:
image: speckle/speckle-preview-service:latest
restart: always
depends_on:
speckle-server:
mem_limit: '1000m'
memswap_limit: '1000m'
environment:
DEBUG: 'preview-service:*'
PG_CONNECTION_STRING: 'postgres://speckle:speckle@postgres/speckle'
webhook-service:
image: speckle/speckle-webhook-service:latest
restart: always
depends_on:
speckle-server:
environment:
DEBUG: 'webhook-service:*'
WAIT_HOSTS: postgres:5432
fileimport-service:
image: speckle/speckle-fileimport-service:latest
restart: always
depends_on:
speckle-server:
environment:
DEBUG: 'fileimport-service:*'
FILE_IMPORT_TIME_LIMIT_MIN: 10
SPECKLE_SERVER_URL: 'http://speckle-server:3000'
networks:
default:
volumes:
postgres-data:
redis-data:
minio-data:
1. Timeout Error for Large IFC File Uploads Exceeding 5 Minutes
I have a scenario where uploading a large IFC file takes more than 5 minutes(With slow internet), which results in a “set time limit” error, despite having configured an environment variable in my Docker Compose file to set a 10-minute time limit for the file import service package.
Despite this configuration, uploads taking longer than 5 minutes fail with a time limit error. I’m looking for insights on why this might be happening and how I can ensure that the set time limit is respected by the service.
2. Errors During the Import Process of Two Different ~1GB IFC Files
In addition to the timeout issue, I’ve encountered two separate errors while attempting to import two different IFC files, each close to 1GB in size, using a high-speed internet connection. The files are uploaded in a few minutes, but the import process fails for each with different errors:
- Error for the First IFC File: “Parser exited with code null”
Error for the Second IFC File: “RangeError: Set Maximum size exceeded”
These issues suggest that the import process struggles with aspects beyond just upload time, possibly related to the files’ content or size. I’ve attached a snippet of the Docker Compose file I’m using for reference.
Given these challenges, I’m reaching out for any advice, workarounds, or solutions that could help address these problems. Additionally, if there are any improvements I could make to my current setup or if there’s anything I might have overlooked, I’d greatly appreciate your input.
Thank you in advance for your help and support.
Vamsi
