Issue with Section Box- Geometry dissapears when i click the section box
Dear Speckle community ,
I have created a new project and have added a couple of models using the Rhino Connector.
When I try to use the section box all the geometry dissappears
i.e.
https://app.speckle.systems/projects/817c4e8daa/models/f0601ef5f9
I tried to add a model another porject and got the same behavior
When I check another project (which i have uploaded models to a month ago or so) the section box is working fine.
https://app.speckle.systems/projects/4c7baa9d75/models/20fb0310ab
I checked the status of the servers and seems fine.
I tried fro different browsers and the behavior is consistent.
Any idea why this is happening?
Hi @EvanP
There is indeed an issue with the section box for streams very far away from origin like the one in your stream
We will put it in our backlog and take care of it as soon as time allows it.
PS: I’ve seen that you managed to figure the issue out by yourself as in the last version the stream is no longer very far off origin and you are not getting the issue anymore.
Cheers
A post was split to a new topic: Section box is missing
