Issue with New Speckle Connector Freezing in Power BI Filters
Hi everyone!
I’ve been running some tests with the new Speckle connector. In the video below, I compare the old connector with the new one. For this test, I uploaded models to the server using both methods and then downloaded the queries independently into Power BI.
As you can see, the old connector works perfectly when applying filters. However, when performing the exact same operation with the new connector, Power BI freezes.
Has anyone else experienced this issue or knows what might be causing it?
Video link: Sign in to your account
Thanks in advance for your help!
We believe that v3 beta 25 addresses this in the new powerBI visual.
https://releases.speckle.systems/v3
Try it out and report back :cool_spockle:
Hi Jonathon,
Thanks for the quick response! :raised_hands:
I’ve already tried installing v3 beta 25 and 19, along with uninstalling the previous versions and testing different setups. Unfortunately, I’m still encountering the same issue. In most cases, Power BI gets stuck on this window, and I’m unable to access the data as required by the new Speckle custom visual.
I’m really excited to test the speed improvements of the next-gen connector, but I’m stuck at this point. Do you have any other suggestions?
Thanks again for your support! :blush:
Hey @Pablo-HorizunAEC,
Thanks for taking the time to test and for reporting this, can you please share your project URL with us so we can take a look? You can post it here or If you want you can send me a direct message.
Thanks you!
Hello Nikos, I can give you the link. Thanks. main - Living Benevento | Speckle
