Issue with 3D Speckle View in Power BI
Description:
Hello Speckle Support Team,
I am experiencing an issue with the 3D Speckle view in Power BI. Although I successfully activated the Speckle connector and mapped the required fields (e.g., Model URL, Version Object ID, Object ID), the 3D model does not render and instead displays as a blank area.
Steps Taken:
  1. The Speckle model displays correctly in the Speckle web viewer.
  2. All necessary fields (Model URL, Version Object ID, and Object ID) are correctly pulled into Power BI, as shown in the attached screenshots.
  3. I have ensured that no conflicting filters or field mapping errors exist.
  4. I’ve refreshed the dataset and rechecked the model in the Speckle web viewer to confirm its integrity.
  5. I’ve cleared Power BI’s cache and reconnected the model, but the issue persists.
  6. A simpler Speckle model loads correctly in Power BI, so the issue appears to be specific to this stream.
Attached Screenshots:
Model Information:
Could you please assist me in identifying what might be causing this issue and how to resolve it? Let me know if you need additional details or access to the Speckle stream.
Thank you for your support!
Best regards,
Yazan
Hey @Yazan,
Welcome to Speckle!
Can you please go to your project settings and make sure your project is set to Link sharable or Discoverable.
Then go back to the Power BI dashboard and try again.
thank you
Hey @Nikos,
I’m having the exact same problem also after making the link shareable
Any suggestion on how to fix it?
Thanks in advance for your support!
Hey @flevjac ,
Can you share the Model URL?
Hey @gokermu
Never mind, I’ve find the solution in this post
The problem was that my data connector was an older version than the visual
I uninstalled the old data connector via the Speckle Manager and downloaded through the following link the newest data connector Connectors | Speckle
