Hi all,
I’m trying to display the model in Ver BI with the new generation of the application. But for some reason, the download feed takes a very long time to update. And as a result, it does not display anything
Hi @_Sergii_Holomah,
If possible could you share the URL with me via DM to investigate whats going on.
Best
Oh, I think I know what’s going on here according to your screenshot. This looks like you created your Query with the previous version of data connector, but you are trying to use new visual.
You can see below what I would expect on the query
And then, it just works with your model on my end
Thank you for your response. I also noticed that I got a different request than in the video example. However, I was installing a new version of the update on Floor B. I don’t understand where I could have gone wrong. How can I get or install the new version of the data connector?
Still, the connector, as I said earlier, has already been updated. Because when I updated again from your link, nothing changed either. Perhaps the reason is that I have 2 viewers installed, both old and new? Or some other reason?
yes it is very much worth removing all old data connectors and visuals
