Issue in Navisworks with Speckle Data Exchange
Hello, I am working in Navisworks with the Speckle application. I have set up the Data Exchange, and when I click ‘Send,’ an error appears:
Send cancelled
Everything Mode is not yet implemented. Send stopped.
What could be causing this error? How can I fix it?
Thank you in advance. Best regards.
Hey @Evelin welcome here, feel free to Introduce yourself :person_gesturing_ok:!
You should be able to select a different selection method from the UI, does that work?
I would also suggest you upgrade to use our latest version of the connector (v3), which can be downloaded from here: Log in | Speckle
@Evelin 1000% endorse what Matteo says on this - the Next Gen v3 Navisworks connector is genuinely the maturation of Speckle Navisowrks out of Alpha.
To explain the error you are seeing, Navisworks models are significantly more object, data and geometry heavy than for other applications. So the simple one-click-send mode was deliberately blocked.
If you want to continue testing the old v2 alpha then choose Advanced send in the Speckle Panel and use the selection modes Matteo describes.
