Intelligence missing url
I’m currently getting the following error message everywhere in Intelligence:
The webpage at bashboards.netlify.app/... seems to be having problems, or it may have been permanently moved to a new web address.
This happens across all Intelligence views on my side.
Is this a known issue, or has something changed with the Intelligence integration / dashboard URLs?
Hi Manuel, thanks for flagging. Intelligence is running normally for other users. From our logs, the dashboard frame never manages to load from bashboards.netlify.app in your browser, so something on your side is blocking that domain.
Could you check:
  1. Does https://bashboards.netlify.app open if you paste it straight into a new Edge tab?
  2. Does it work from a phone hotspot, or on a personal device outside the company network?
If 2 works and 1 doesn’t, your IT team will need to allow bashboards.netlify.app through your firewall, proxy or web filter. *.netlify.app is often blocked by default in corporate filters.
Thank you @jonathon , that was the issue! I’ve to check that out.
