CONVERSION ERRORS
Unable to cast object of type 'Objects.Geometry.Line' to type 'Objects.Geometry.Curve'.
Unable to cast object of type 'Objects.Geometry.Polyline' to type 'Objects.Geometry.Curve'.
Is this simply an unsupported conversion?
This is a QGIS generated stream read into Revit.
Should I use Grasshopper with SpeckleToRevit tools?
I was just tidying up from a long stream of messy commits.
Direct from QGIS
CONVERSION ERRORS
Tried Exploding Polylines in Grasshopper
CONVERSION ERRORS
Created Revit Model Lines in Grasshopper
CREATED: 205
03/02/22 12:10:54 The input point lies outside of Revit design limits.
Parameter name: origin
I translated the model because it was in OS space
CONVERSION ERRORS
03/02/22 11:47:51 Curve length is too small for Revit's tolerance (as identified by Application.ShortCurveTolerance).
Parameter name: endpoints
03/02/22 11:47:49 Using converter: ConverterRevit v2.3.0.9631
03/02/22 11:47:49 Using document:
03/02/22 11:47:49 Using units: mm
03/02/22 11:47:51 Created ModelCurve 433247b9e2ffd531c9bd-Objects.BuiltElements.Revit.Curve.ModelCurve-0
03/02/22 11:47:51 Created ModelCurve 433247b9e2ffd531c9bd-Objects.BuiltElements.Revit.Curve.ModelCurve-1
Hey @GabrielGarcia, I wasn’t able to reproduce this on my end sending grasshopper curves to Revit: could you push the grasshopper curves to a stream on speckle.xyz? I don’t have access to RHDHV’s server
@jonathon@GabrielGarcia
Just finished investigating the Unable to cast object of type errors, and this was actually caused by curves that are located very far from the internal origin in Revit (same exception as The input point lies outside of Revit design limits) when the exception just wasn’t reported correctly.
The current fix is now reporting the exception correctly, however it won’t result in the curves actually being created in Revit. We don’t have a good solution yet for handling civil scale geometry import into Revit, but in the meantime you could try the new settings feature in the Revit connector: (1) setting the survey point close to the originating geometry, and then (2) receiving the commit relative to the survey point to see if that might work.
Thank you @clrkng. This is a stream received from a Grasshopper component we made to download open data from the Netherlands. The position of the geometries in this case is important because it refers to the national coordinate reference system. This is why there is also a problem with the GIS data from @jonathon.
I understand that there is no immediate solution for this but if you change the error message, at least the user knows why the data cannot be imported into Revit and take some action.
