Hi, I export geometry from Grasshopper and name export categories according to the layers I wish to establish in Rhino. It does this but everything is on layer ‘default’. Any suggestions as to what I am doing wrong? I ideally would like to transfer layer colours as well.
I have screen-shots but cant seem to upload them.
You should be able to cut & paste images into the message directly
To summarise what I think I understand your question to be
- Sets of Geometry objects defined in GH
- You would like to structure the version commits sent to Speckle so that these elements are allocated to specific layers when received in Rhino
- You would also like to define Layer colours.
Do you expect these to update if the Rhino layers already exist?
Yes, I am able to name elements of a stream when I send but ideally the geometry in these should end up on the layer that speckle creates. If the layer already exists in Rhino they could merge.
Does this make sense? I have rewritten my app to use Speckle exclusively but everything ending up on layer default’’ is problematic. Thaks for replying and sorry for the delay in getting back to you
@PhilSouthwell, just a quick update: @clrkng is on to it already! It’s a backwards compatibility issue we introduced
We’ll get those yachts baked on the proper layers soon!
Awesome… Thanks Dimitie. Did you get the stuff I emailed you? Speckle is a dominant part of the enterprise version and so much easier to implement than the BIM / Baking of EleFront…
Here’s the new Grasshopper model layout (all the blue is Speckle): Dropbox - SCreen capture.png - Simplify your life
I did receive your email and the docs you sent me, meaning to get back to you! Once we iron out these quirks, we would love to put out a case study on this if you agree as well.
If this is a general Layer topic. A further option (which I think many Rhino users would find useful) is to use a key-value pair (key-layer) to add more granular control.
I think a ‘block’ - created using the Generic Data field in the Send component - could be assigned to the resulting layer in Rhino (named after the Generic Data element). Software that use blocks predominantly which benefit and items assigned the Key-value Layer or sub-layer would be very flexible. Obviously, we could program that assignment.
