Lorsque j’importe dans Speeckle des IFC 4 certaines formes arrondies ne sont pas ou mal interprétées. Dans les viewer IFC la forme est respectée et en format 2x3 dans Speeckle pas de problèmes non plus .
Merci pour votre aide.
When I import IFC 4 into Speeckle, some rounded shapes are not or are misinterpreted. In the IFC viewer, the shape is respected and in 2x3 format in Speeckle, no problems either. Thanks for your help.
Thanks for the report @gaetandenis . We rely on the parser from IFCjs, so if it handles IFC4 geometry in this way then so may we.
We are currently rewriting our work in the background, starting with the most cutting-edge version of that library. If you could share an example file with us, it would help us check the progress of that effort.
