Hello there,
I have the same issue.
Last week I updated many IFC’s without a problem.
Today, it refuses to upload even the same (really light) files I uploaded before.
I tried using a different project, but the problem persists.
I also tried using a different browser.
Thank you in advance
Hello!
The same issue.
I’ve dragged and dropped a very little IFC and didn’t work.
(IFC 4, 575 Kb)
Hey @Sebastian_Duque_Mahe ,
Sorry to hear you are having issues. Can you share the problematic IFC file with us? You can send a DM if you don’t want to drop it here.
Hey @5151 ,
Can you also share the problematic IFC file? Feel free to send a DM if you don’t want to share it publicly?
HI!
Linked both versions : Ifc 4 and Ifc 2x3
https://www.dropbox.com/scl/fo/afic1xqphbotlgllqc1vm/AF37EpDmWkgK2sreFpBubQ0?rlkey=tlemjg9ejo7c0dlrzzl83zfr8&st=nukgtidr&dl=0
Hello, Thank you for your reply.
I’d like to share the model in DM, could you explain me how?
best,
Sebastian
I’m also having issues uploading IFCs. They were generated from different software, so the problem should not be related to the files themselves.
I will share with @gokermu the IFCs files.
2 posts were split to a new topic: How to hide part of a federated model?
Yes, it works know.
It just need a page refreshing (it shows uploading, but when refreshing it’s ok, the model is there)
Best regards
It works for me, too.
Thank you!
I’m experiencing the same issue again with the IFC upload, stuck on “Uploading new version” since 14:00 yesterday.
I attempted to delete the model folder, but it wasn’t possible. I also created a new model folder, but I still can’t upload any files—the upload simply doesn’t start.
The file I’m trying to upload is an IFC that was imported into Revit. I deleted some parts of it, exported it as a new IFC, and then manually tried to upload it to Speckle.
Thank you.
We are actively working on this issue right now @amagro on two fronts -
- A better UX when the ifcjs parser fails
- A replacement for the ifcjs parser.
- apologies for the poor experience.
