I can´t connect my rhino 8 to speckle
Thank you for seeking help! Our friendly community is here to assist you. :pray:
  • Speckle Status: Please check that our systems are up and running: https://status.speckle.systems/
  • Objective: What are you trying to achieve, e.g. Receive Blender data in Excel, Use REST to query comments, …
  • Issue: If you suspect a bug, describe what you expect to happen. Explain what is happening or failing to happen. If you instead need a guiding hand, where are you stuck?
  • Example: Help us reproduce the issue by attaching sample files, giving a step-by-step reproduction guide and screenshots/videos if available
  • Speckle link: What better way to share data than using Speckle?
  • Logs: If the issue regards our desktop connectors, please share the relevant logs you find under: %appdata%/Speckle/Logs
    Captura de pantalla 2025-02-17 110525
    Captura de pantalla 2025-02-17 110926
hi @Angelica_Ramirez - can you access https://app.speckle.systems? It’s a weird error.
hi, thanks for reply
i dont know what to do in the website bc i can´t find where to solve it
i also try to logging out and logging in, removed that account from Speckle Manager and signed it in again
Hey @Angelica_Ramirez,
I’m sorry to hear that you’re experiencing this issue. Could you please do two things for me?
  1. Try running the SpeckleBeta command in the command line and see if you can publish using the Next-Gen Rhino connector. This connector should be installed alongside the current version if you have the latest update.
  2. Please share the text file located under %appdata%\Speckle\Logs\rhinoRhino 8. It should have today’s date and will be named SpeckleCoreLog20250217.txt.
Thank you!
ii cant upload the file
how did can i send it to you?
I have bumped your trust level up - please try again - apologies we’ve had a lot of spammers.
SpeckleCoreLog20250217.txt (467.2 KB)
thank youuuuu
Do you have any corporate VPNs enabled?
Or are you using any corporate networks that may have restrictive network firewalls or something that might be blocking network access to specke servers?
I suggest dissabling any VPNs, and trying a different network (maybe a mobile hotspot) and see if there’s any improvement.
no i don’t have any VPN and neither network firewalls
i don’t know what is the problem because i already did all of the tips :frowning: and nothing
Could you please try connecting from a different network, like a mobile hotspot? Additionally, if you are using a cracked version of Rhino, there might be some firewall rules preventing Rhino from connecting to the internet. Please check your firewall’s outbound rules by following these steps:
  1. Open Windows Defender Firewall (search for “Windows Defender Firewall” in the Start menu).
  2. Click on “Advanced settings” in the left panel.
  3. Select “Outbound Rules” from the left sidebar.
  4. Look for any rules related to Rhino or rhinoceros.exe.
  5. Right-click on the blocking rule and choose “Delete.”
  6. Restart Rhino.
Let me know if that helps!
thank you so so much
it finally works :))
