Hello everyone!! For some reason I can´t access my account streams or add new streams, but my Revit connector is working fine. I have already downloaded the connector various times but it doesn´t seem to work.
Everytime I try to create a new stream it appears this:
This looks like a connection issue due to a firewall/VPN. In addition to what Jonathon said, could you please send us your logs?
The latest Rhino or Revit one is enough, you can find them in: %appdata%\Speckle\Logs.
Here are also the addresses that need to be accessible by Speckle: FAQs | Speckle Docs
It would appear that your connections to some of our server infrastructure are blocked. As @teocomi asked, are you on a corporate network with firewalls or using some other VPN or remote server?
A little confusing is that you say one connector is making a connection, and the other is not.
Does “fine” mean the Revit Connector connects with Speckle or is it loading in Revit but then failing?
