How to using Speckle to save revit file in lower version (Example .rvt 2024 to .rvt 2015)
I don’t know if this is possible yet, but saving to the lower .rvt file format is getting difficult. I assume a lot of people need this, let me know if anyone has done it
We’ll be totally transparent here, others have discovered this ability, tweeted about it, presented it on stage at SoeckleCon even made YouTube videos.
Speckle doesn’t advertise or claim this as a feature we support. Not supporting something is not the same as preventing it, but if it sometimes works for you Great, if not it’s a shame.
Revit 2015 is always going to be a long shot anyhow. The way speckle works is to use the internal API available in each version. Autodesk moves slowly but it does at least improve of versions and in the API too.
Is there any guideline for this?, I am not sure if I will use revit 2015, even versions from 2022-2023 are also used by me
We have no plans to document supported conversions in older versions.
Fair to see that we have several reports of missing elements sending from Revit 2021 related to MEP. This indicates poor support for MEP in 2021 and earlier.
Thanks, maybe I’ll look for another idea.
