Is there any way to find numbers of floors in of building …
Probably several ones! Where are you hacking this - python, js, .net - and what’s the source of your data (e.g., revit, navis, etc.)?
This should help us narrow down things!
the source of my data is revit and using Javascript.
what is this ?
I Think you didn’t understand my question. Actually ,I am asking that how to get the number of floors and roofs in a building.
Hey @Sachin_Kannaujiya the code above shows how to list all the floors in a stream using javascript, give it a go and let us know!
can you please give graphql query for this ?
Thanks . I tried this and its work .
You’re probably using an outdated version of node. If you do node -v what do you get out of it?
Otherwise, in node, it’s an easy fix: https://github.com/specklesystems/speckle-server/tree/main/packages/objectloader#on-the-server
Can I use with version node lower ? At the moment I have some depend with v18.12.0, your link is useful now.
Node18 LTS is the target version
That message is a WARN type, it will not stop you from using the package.
But the cause of the warning is our bad, we’re going to relax the node version requirements a bit.
As a sidenote, we recommend using a version manager for switching between nodejs versions in different projects.
On mac / linux its nvm
and on windows you can use nwm-windows
This will allow u to use node 18.12 in one project and a completely different version in another.
Thanks @jonathon @gergo @dimitrie , I guess upgrade LTS is best way to follow with team, but some another package they don’t follow with latest npm, I wish have a version package better npm now but nope, because it is javascript . ![]()
Hey @chuongmep Dimitrie’s code with some minor modifications, is fully compatible with your version of node. I was able to run the code below in a node 18.0.0 environment.
const ObjectLoader = require("@speckle/objectloader")
async function getLevelsAndCountRoofs() {
const streamId = "c1faab5c62";
const objectId = "1849e1f072b577ed02e8618f75a0b799";
const serverUrl = "https://latest.speckle.dev";
const loader = new ObjectLoader({
serverUrl,
streamId,
objectId,
options: {
enableCaching: false,
let levelsMap = {};
const allRoofs = [];
for await (const obj of loader.getObjectIterator()) {
if (obj.level) {
levelsMap[obj.level.name] = obj.level;
// Objects.BuiltElements.Roof:Objects.BuiltElements.Revit.RevitRoof.RevitRoof:Objects.BuiltElements.Revit.RevitRoof.RevitExtrusionRoof
if (obj.speckle_type.includes("Objects.BuiltElements.Roof")) {
allRoofs.push(obj);
console.log("Here are all the leves:", levelsMap);
console.log(`There are ${allRoofs.length} roofs in the model.`);
return levelsMap;
void getLevelsAndCountRoofs();
Thank you @gergo , I will add more sample with react app for any guy want explore power of speckle ![]()
