Hello everyone!
I’m excited to be a part of the Speckle System community. I need your assistance with a challenge I’ve encountered.
Recently, I attempted to customize some minimal features of the Speckle System and uploaded the updated code to GitHub. However, after cloning the code again, I faced issues when trying to run it.
Here’s the error message I encountered:
[@speckle/server]: [server] [nodemon] app crashed - waiting for file changes before starting...
[@speckle/server]: [gqlgen] {"@l":"Error","component":"redis","err":{"type":"Error","message":"connect ECONNREFUSED 127.0.0.1:6379","stack":"Error: connect ECONNREFUSED 127.0.0.1:6379\n at TCPConnectWrap.afterConnect [as onco
mplete] (node:net:1555:16)","errno":-4078,"code":"ECONNREFUSED","syscall":"connect","address":"127.0.0.1","port":6379},"@t":"2025-03-20T12:23:45.550Z","@x":"Error: connect ECONNREFUSED 127.0.0.1:6379\n at TCPConnectWrap.afterConnect [as oncomplete] (node:net:1555:16)","@mt":"Redis encountered an error."}
[@speckle/server]: [gqlgen] C:\Users\tjany\Documents\work\VectoAPI5\packages\server\modules\shared\redis\redis.ts:16
[@speckle/server]: [gqlgen] throw new EnvironmentResourceError('Redis encountered an error.', err) //FIXME backoff and retry?
[@speckle/server]: [gqlgen] ^
[@speckle/server]: [gqlgen] EnvironmentResourceError: Redis encountered an error.: connect ECONNREFUSED 127.0.0.1:6379
[@speckle/server]: [gqlgen] at EventEmitter.<anonymous> (C:\Users\tjany\Documents\work\VectoAPI5\packages\server\modules\shared\redis\redis.ts:16:15)
[@speckle/server]: [gqlgen] at EventEmitter.emit (node:events:517:28)
[@speckle/server]: [gqlgen] at EventEmitter.emit (node:domain:489:12)
[@speckle/server]: [gqlgen] at EventEmitter.silentEmit (C:\Users\tjany\Documents\work\VectoAPI5\node_modules\ioredis\built\Redis.js:482:30)
[@speckle/server]: [gqlgen] at Socket.<anonymous> (C:\Users\tjany\Documents\work\VectoAPI5\node_modules\ioredis\built\redis\event_handler.js:196:14)
[@speckle/server]: [gqlgen] at Object.onceWrapper (node:events:632:26)
[@speckle/server]: [gqlgen] at Socket.emit (node:events:529:35)
[@speckle/server]: [gqlgen] at Socket.emit (node:domain:489:12)
[@speckle/server]: [gqlgen] at emitErrorNT (node:internal/streams/destroy:151:8)
[@speckle/server]: [gqlgen] at emitErrorCloseNT (node:internal/streams/destroy:116:3) {
[@speckle/server]: [gqlgen] jse_shortmsg: 'Redis encountered an error.',
[@speckle/server]: [gqlgen] jse_cause: Error: connect ECONNREFUSED 127.0.0.1:6379
[@speckle/server]: [gqlgen] at TCPConnectWrap.afterConnect [as oncomplete] (node:net:1555:16) {
[@speckle/server]: [gqlgen] errno: -4078,
[@speckle/server]: [gqlgen] code: 'ECONNREFUSED',
[@speckle/server]: [gqlgen] syscall: 'connect',
[@speckle/server]: [gqlgen] address: '127.0.0.1',
[@speckle/server]: [gqlgen] port: 6379
[@speckle/server]: [gqlgen] },
[@speckle/server]: [gqlgen] jse_info: { code: 'ENVIRONMENT_RESOURCE_ERROR', statusCode: 502 },
[@speckle/server]: [gqlgen] cause: [Function: ve_cause]
[@speckle/server]: [gqlgen] yarn gqlgen:watch exited with code 1
[@speckle/webhook-service]: WARN: Connection Error: Connection ended unexpectedly {"component":"webhook-service"}
[@speckle/webhook-service]: node:internal/process/promises:288
[@speckle/webhook-service]: triggerUncaughtException(err, true /* fromPromise */);
[@speckle/webhook-service]: ^
[@speckle/webhook-service]: Error: Connection terminated unexpectedly
[@speckle/webhook-service]: at Object.raw (C:\Users\tjany\Documents\work\VectoAPI5\node_modules\knex\lib\knex-builder\make-knex.js:116:30)
[@speckle/webhook-service]: at Function.value (C:\Users\tjany\Documents\work\VectoAPI5\node_modules\knex\lib\knex-builder\make-knex.js:92:29)
[@speckle/webhook-service]: at startTask (C:\Users\tjany\Documents\work\VectoAPI5\packages\webhook-service\src\main.js:17:29)
[@speckle/webhook-service]: at C:\Users\tjany\Documents\work\VectoAPI5\packages\webhook-service\src\main.js:128:30
[@speckle/webhook-service]: at Array.map (<anonymous>)
[@speckle/webhook-service]: at doStuff (C:\Users\tjany\Documents\work\VectoAPI5\packages\webhook-service\src\main.js:126:19)
[@speckle/webhook-service]: at async main (C:\Users\tjany\Documents\work\VectoAPI5\packages\webhook-service\src\main.js:167:3) {
[@speckle/webhook-service]: originalStack: 'Error: Connection terminated unexpectedly\n' +
[@speckle/webhook-service]: ' at Connection.<anonymous> (C:\\Users\\tjany\\Documents\\work\\VectoAPI5\\node_modules\\pg\\lib\\client.js:132:73)\n' +
[@speckle/webhook-service]: ' at Object.onceWrapper (node:events:631:28)\n' +
[@speckle/webhook-service]: ' at Connection.emit (node:events:517:28)\n' +
[@speckle/webhook-service]: ' at Socket.<anonymous> (C:\\Users\\tjany\\Documents\\work\\VectoAPI5\\node_modules\\pg\\lib\\connection.js:107:12)\n' +
[@speckle/webhook-service]: ' at Socket.emit (node:events:529:35)\n' +
[@speckle/webhook-service]: ' at endReadableNT (node:internal/streams/readable:1400:12)\n' +
[@speckle/webhook-service]: ' at process.processTicksAndRejections (node:internal/process/task_queues:82:21)'
[@speckle/webhook-service]: }
[@speckle/webhook-service]: Node.js v18.20.7
[@speckle/server]: [server] ERROR: Preview generation failed {"component":"preview"}
[@speckle/server]: [server] err: {
[@speckle/server]: [server] "type": "Error",
[@speckle/server]: [server] "message": "read ECONNRESET",
[@speckle/server]: [server] "stack":
[@speckle/server]: [server] Error: read ECONNRESET
[@speckle/server]: [server] at TCP.onStreamRead (node:internal/stream_base_commons:217:20)
[@speckle/server]: [server] "errno": -4077,
[@speckle/server]: [server] "code": "ECONNRESET",
[@speckle/server]: [server] "syscall": "read"
[@speckle/server]: [server] }
[@speckle/frontend-2]: [0] ERROR: / request failed in 10 ms {"browser":false,"speckleServerVersion":"unknown","serverName":"local","frontendType":"frontend-2","serverLogger":true,"req":{"id":"50828a10-d6b1-44dd-9bee-411d5a547754
","method":"GET","path":"/","headers":{"x-request-id":"50828a10-d6b1-44dd-9bee-411d5a547754","accept-language":"de-DE,de;q=0.9,en-US;q=0.8,en;q=0.7","accept-encoding":"gzip, deflate, br, zstd","sec-fetch-dest":"document","sec-fe
tch-user":"?1","sec-fetch-mode":"navigate","sec-fetch-site":"none","accept":"text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7","user-agent":"
Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/134.0.0.0 Safari/537.36","upgrade-insecure-requests":"1","sec-ch-ua-platform":"\"Windows\"","sec-ch-ua-mobile":"?0","sec-ch-ua":"\"Chromium\
";v=\"134\", \"Not:A-Brand\";v=\"24\", \"Google Chrome\";v=\"134\"","cache-control":"max-age=0","connection":"close","host":"127.0.0.1:8081","x-forwarded-for":"127.0.0.1","x-forwarded-port":"52302","x-forwarded-proto":"http"}},"res":{"statusCode":500,"isRequestAborted":false},"responseTime":10,"requestStatus":"failed","requestPath":"/"}
[@speckle/frontend-2]: [0] err: {
[@speckle/frontend-2]: [0] "type": "Error",
[@speckle/frontend-2]: [0] "message": "failed with status code 500",
[@speckle/frontend-2]: [0] "stack":
[@speckle/frontend-2]: [0] Error: failed with status code 500
[@speckle/frontend-2]: [0] at onResFinished (C:\Users\tjany\Documents\work\VectoAPI5\packages\frontend-2\node_modules\pino-http\logger.js:110:39)
[@speckle/frontend-2]: [0] at ServerResponse.onResponseComplete (C:\Users\tjany\Documents\work\VectoAPI5\packages\frontend-2\node_modules\pino-http\logger.js:173:14)
[@speckle/frontend-2]: [0] at ServerResponse.emit (node:events:529:35)
[@speckle/frontend-2]: [0] at onFinish (node:_http_outgoing:1008:10)
[@speckle/frontend-2]: [0] at callback (node:internal/streams/writable:555:21)
[@speckle/frontend-2]: [0] at afterWrite (node:internal/streams/writable:500:5)
[@speckle/frontend-2]: [0] at onwrite (node:internal/streams/writable:480:7)
[@speckle/frontend-2]: [0] at WriteWrap.onWriteComplete [as oncomplete] (node:internal/stream_base_commons:106:10)
[@speckle/frontend-2]: [0] at WriteWrap.callbackTrampoline (node:internal/async_hooks:128:17)
[@speckle/frontend-2]: [0] }
Could anyone shed light on why this might be happening and how I can fix it? Any guidance would be greatly appreciated!
Thank you!
