Is it possible (and if not, can you add an option so it is possible) to tell the Speckle dockable window in Revit not to open every time I open Revit? I don’t use Speckle on every project and having this window open every time I open Revit is a minor annoyance and an extra click every time.
@Eric_Stimmel I believe the panel should only open if:
- it was open in the previous session
- you click to launch the connector itself
- if the file contains any saved Speckle streams/projects (I need to double check this one)
If it’s opening every single time you launch Revit, then we should definitely fix that.
A post was split to a new topic: IFC imports causing Revit to crash
@teocomi - Thanks for the explanation. I did some additional testing by opening Revit 2021-2024 and starting a new file from the <none> Revit template option and the Speckle window does in fact behave as you described. I’ll pay closer attention to the circumstances around when I see that window open from now on and try to provide some meaningful insights if it’s deviating from this behavior.
