Hi. I am a Speckle newbie and a Streamlit newbie. But I have managed to get Streamlit to talk to Speckle and I can get commits, change their attributes and put a new commit back on the server all through Streamlit and specklepy (and Topologic).
I have also successfully deployed the app to the Streamlit Cloud. Topologic work, speckle works, but I am having trouble getting an authenticated app to see the streams etc.
I DID add an Application to my speckle profile and noted down the App ID and the App Secret.
I also managed to input that into Streamlit and go to the authentication page, click on Allow and it redirects back to my Streamlit app. And when that happens, I can even get the ‘access_code’ as they call it which I assume is the token that I need, but then, this code does not authenticate the app
In brief, the speckleToken will be an OAuth token. The access_code is what your APP should use to complete the authorization flow.
i.e. your APP (registered as an app in your profile settings) should exchange the access_code for it as the next step in the authentication flow.
by way of a python example:
user = {
"email": "{{USER_EMAIL}}",
"password": "{{USER_PASSWORD}}"
# How your app registers itself as approved by the user
response = requests.post(
url=f"HTTP(s)://{{HOST_URL}}/auth/local/register?challenge={{CODE_CHALLENGE}}",
data=user,
access_code = response.url.split("access_code=")[1]
Where CODE_CHALLENGE is the plain text OAuth code challenge. (read more here)
At this point, tokens should be a JSON object with both a token and a refreshToken
If we ignore the latter distinction, for now, the token is what is the speckleToken in your example code. The token expiry rate of a Speckle server escapes me for now. In truth, there is no harm in always requesting a new token using a refreshToken between sessions. If you pay by the HTTP request, hold on to the token for as long as possible.
EDIT: The default lifespan of a token appears to be 10 minutes, and the default lifespan of a refreshToken is 6 months. Or 100000 years - I haven’t quite gotten the bottom of it
That is, of course, assuming you want users to authenticate your APP to use their Speckle accounts and content. If you just want to run it as yourself, then you can use Personal Access Tokens instead.
Thank you. I think I found the issue and it has nothing to do with Speckle. It seems upon return from getting an access code, the Streamlit app code is generating a brand new challenge string rather than using the one saved in the session. It seems it is creating a new session at the redirect url.
