Grasshopper and jupyter notebook (pandas)
I find that when loading in excel or csv files into grasshopper- its hard to work with the data aswell as you could with say pandas. I know there are ways around this- however- i wondered if its possible to create a direct stream between grasshoppee data and a jupyter notebook- where i could manipulate data in a much easier environment and either visualise or even pass back sorter data?
I suppose the workaround if this is not possible is to just deal with excel files- but it would be really nice if there was some back and forward workflow?
Thankyou
Hey @ssw,
It’s unclear if this is a Speckle data question or more a general using Jupyter/Pandas with Grasshopper question.
What are you looking to achieve? What data manipulations are you attempting?
It is a speckle question- i want to be able to pass data from grasshopper into jupyter notebook
And wondered if there is a speckle connector to do this? I saw a tutorial about creating a dashboard that uses pandas with speckle- but i would like to be able to use jupyter to have visual feedback-
Does that make sense?
ok gotcha
Your first post described manipulating excel data more easily within Jupyter than Grasshopper, if you want to do that your best approach to using Jupyter-manipulated data within Grasshopper is probably to push the results to a speckle branch and consume it in Grasshopper.
How you get the information into jupyter is up to you. If the source is simply excel/vs then the basic csv library would probably suit.
df = pandas.read_csv("data.csv")
and then you can use specklepy to publish that to a stream.
In your follow-up, you want to pass grasshopper data to Jupyter. Again simply importing specklepy into your notebook to consume a stream/branch/commit produced in Grasshopper
Thankyou- silly question but is there a way i can get say a list from grasshopper directly into jupyter? Or would i need to take the gh list write it to a cvs or excel and then read it with pandas?
Thankyou for your help
Yes, there is. As @jonathon mentioned, you can use speckle’s Python SDK, specklepy. Take a look at the following links, I’ll try to share some code in the morning.
But not directly to the GH runtime, you will have export a file of some sort.
Not sure this would fit what you want. Trying to get it to work on a Jupyter notebook may require a bit more headaches, but if you only need to run pandas stuff on a script, this may actually do the trick for you way better than anything you were planning:
Hops is a new plugin for Grasshopper that enables using Rhino.Compute for some crazy complex use-cases, it is quite powerful but I’d confess I haven’t poked around with it much
@AlanRynne and @ssw I’m tempted to try this out now :smiley:
That looks great, the reason I like jupyter notebook is i can see graphical feedback on both my data frames and any visualisations I do- do you think that would be possible using this?
Hey @ssw ,
I created a simple POC that gets the latest commit sent from GH to the below stream. Take a lookšŸ‘€
GH_Data
Received in Jupyter
Stream Used
https://speckle.xyz/streams/275f928307
Once received in Jupyter, you can do whatever you want with it. Use pandas, matplotlib etc.
Amazing- can i then go back the other way with speckle- rather than exporting our a csv for example?
absolutely, we’ll expand this a little bit and probably make a tutorial post or at the least a community forum post about it.
Would this tutorial you have made- work with this workflow?
The reason i ask- would be- could you then be able to graphically see the dataframes? How does pandas display just in something like visual studio?
I see no reason for it to not work. I did use stremlit for the UI in that tutorial. So modify the code according to Jupyter and you’ll be good to go.
This is how DataFrames look like in VSCšŸ‘‡.
