Graphql request failed without a graphql response / Could not get streams from this account
in rhino i can not use my streams… and i get this eror when i want to create new stream Graphql request failed without a graphql response
and also get the error could not get streams from this account
Hey @kimiya_gholami ,
Welcome to the community! Can you please share:
  • the relevant logs you find under %appdata%/Speckle/Logs (just copy and paste in the windows address bar)
  • What server are you using?
  • Does any other connector work, eg Revit?
  • Can you reproduce from another network (eg home wifi)?
A post was merged into an existing topic: Graphql request failed , while transferring object from rhino to Revit
