Expected
Passing an Account and a Stream ID to an sGet
should return the stream of that id at the appropriate host server.
Observed
Instead, in the screenshot above it appears to default to latest.speckle.dev
which was the default account I set in Manager. Changing the default account in Manager corrects the error (after a bit of jiggling to force a recalculation)
When passing a Url it correctly resolves to the correct server and account regardless of the Manager settings.
I’m assuming this ends up in @AlanRynne’s intray
