Get commit_id when Speckle 2.0 has model_id?
Hi, quick question.
Old models have in their URL a commit_id included such that the wrapper extracts the commit_id and we can call:
commit_obj = client.commit.get(wrapper.stream_id, wrapper.commit_id)
For Speckle v2, I only get model_id, but the commit_id is empty.
commit_obj = client.commit.get(wrapper.stream_id, wrapper.model_id)
does not give the Base object. Where is the error in my thinking? Do I have the wrong URL or do I have to use a different function?
Thank you in advance!!
Hey @janix ,
As you might know, Commits have been renamed to Versions in the new frontend.
They are a bit trickier to find: simply expand the model history, and click on a version. Its commitId will be appended to the URL after the @.
I’m not familiar with the Python SDK and I’m not sure if the wrapper already supports the new URL structure, but @gergo and @Kateryna should know :slight_smile:
Apologies if everything has not been properly updated & documented yet, we’re in the process of doing so!
As @teocomi says, not all the underlying SDKs have fully implemented both terminology sets yet.
Consequently, depending on how full a URL you pass to the StreamWrapper, you will indeed get different results between the new URL schema (projects and models) and the legacy (streams and branches)
If you directly address a version in the new schema, as per Teo’s screenshot, this will be signified with an @, and StreamWrapper will return this as a commit_idyes, backwards compatibility has a cognitive load
https://app.speckle.systems/projects/395d60e295/models/c25813b37a@2cd9521ac3
wrapper.commit_id => 2cd9521ac3
If instead, you are only passing the bare URL of a model: e.g. https://app.speckle.systems/projects/395d60e295/models/c25813b37a
You will need to retrieve the versions such that:
# Initialise StreamWrapper and retrieve model and commit IDs
wrapper = StreamWrapper(
    "https://app.speckle.systems/projects/395d60e295/models/c25813b37a")
commit_id = wrapper.commit_id
# Fetch commit and create a transport for operations
if commit_id is None:
    stream = client.stream.get(wrapper.stream_id)
    model = next((branch for branch in stream.branches.items
                  if branch.id == wrapper.model_id), None)
    commit = model.commits.items[0] if model else None
transport = ServerTransport(client=client, stream_id=wrapper.stream_id)
# Retrieve and process the referenced object if commit is available
commit_data = (operations.receive(obj_id=commit.referencedObject,
                 remote_transport=transport) if commit else None)
Late repsonse, but your code fixed the problem. Thanks!!
