GeometryNodes missing in de Power BI data-set
I encountered a problem I do not understand. I want to publish geometry from Navisworks to Power BI, but from some objects, the GeometryNodes are missing in the power bi data-set; the models.collection are there. Below the steps
(1) Select 2 object in Navisworks and publish to Speckle Online
(2) Within Speckle Online, when selecting an object i see the the ‘GeometryNode’ and the properties
(3) When loading the data into power bi, only 1 object is loaded as ‘GeometryNodes’
So the questions I have
(1) Should the GeometryNode be there of both geometrical objects with the current workflow?
(2) Is my assumption correct the GeometryNodes are needed in the data-set to extract the properties of the geometry and make it selectable in de viewer
(3) Does it matter how/ on which level the geomtry is selected in Navisworks before its send to Speckle, in order to get the GeometryNodes in the data-set
Versions
Snap-2024-09-17-09-36-47
Snap-2024-09-17-09-37-39
Thanks in advance,
Douwe
Hey @D.S_Bosma,
Can you please share with us the project URL? Make sure the project is set to “Link Sharable”.
Thank you
Hi, below the link;
https://app.speckle.systems/projects/302e95d4cb/models/058af6f9e0
Hi Nikos
Do you have any update upon this topic?
I Have the same problem with other models in Power BI unfortunately :frowning:
@Nikos: do you have any update upon this topic?
I now have the same problem, but with another project and a different CAD tool (Open Roads). Within the online speckle viewe, once an object is selected the ‘speckle_type Objects.Core.Models.GeometryNode’ is visible, but within power bi these types are not there. And therefore no objects can be selected and no information is there
I can’t think of a reason why a Navis model visible in the web application would not be retrievable in PowerBI data connector, regardless of the source.
We’ll need more to work with here.
Is there anything i can do/ deliver in order to help?
As ever share a speckle url is a good first step
I’ve taken a look at each of your shared models. Your original report and the last report is legit - can see the issue you are reporting - I will raise the development ticket - apologies this didnt happen earlier.
Incidentally, I made a fix for Navisworks connector last week that will appear later today/tomorrow as a WIP release. This addresses a minor issue I see exhibited in the station model propagating properties from collection to Geometry Node.
Keep an eye out, download and try uploading the data again.
I have tried the next gen navisworks connector with the station model and the objects (Objects.Data.DataObject:Objects.Data.NavisworksObject) are loaded into the report and visible in the (v2) power bi viewer :smiley:
This is a lucky occurrence but definitely something I had in mind. Secondly the next Gen PowerBI also addresses an underlying cause of the original problem so this is further good news coming imminently.
I Saw the Power BI v3 is out! After downloading and running the installation, the .mez file seems to be updated. Also, i installed the powerbiSpeckleVisual-2.19.0.
When i try import the model i have tested earlier uploaded with the Navisworks V2 publisher
(nodetest - DV_Testing | Speckle), I still got a null value and only 1 speckle GeometryNode
Hey @D.S_Bosma ,
You need to uninstall the Speckle.pqx file if you have placed Speckle.mez file in the Custom Connectors folder.
What @gokermu said, but I also got caught up by the name change in the data sources list.
Thanks for the reply! The data seems complete now :grinning:!
Where can i find the model URL and Version object ID?
The new data connector includes its own visual, which is incompatible with the old visual. You can find the new visual in the Documents/Power BI Desktop/Custom Visuals folder. To use it, simply drag and drop the “Viewer Data” column from the “Viewer Data - nodetest” query into the Viewer Data input of the visual, and do the same for the Object IDs.
Please note that this is an early alpha version; we have not officially announced or documented any of these features yet.
Thank you for sharing, I gave it a quick try and is works!
Hi @gomerku
I’d like to try the early alpha of version V3, but I can’t find it on GitHub. Where can I find it?
