What do i want to do:
I have a couple of different Generic model adaptive (I will refer to them as GMA). I want to send these files toward Speckle and use them in another project.
Information about the GMA:
The GMA consist of 3 GMA’s inside it, these have shared checked on. This GMA is from a third party.
Problem:
When I try to “reveive” them into my other project they fail to find the needed type and do not get loaded into the file. It looks like Speckle is replacing the wanted family type with antoher type that is unrelevant to the main family that was used originally.
What i have done so far:
It might have trouble gathering the information of the GMA Lets try and see what it does to another GMA(this one has 3 GMA in it as well).
Again Speckle could not load the wanted family type. It replace the type with a already loaded family type that was in the used template(left image). It appears that Speckle requires Revit to have the family and its types already loaded to be able to create them.
Lets see if it helps to pre load the family. When we preload a home made GMA it works(right image). Even if it has shared checked on.
Seems like it does help.
Now we want to check if its possible to load the wanted elements in the original File that has the families and their types already loaded. If this is succesvol we can conclude that this is the problem. We delete the objects that have been send to Speckle.
After trying to receive them again from Speckle we get the same issue. Speckle was unable to load the needed types and replaced them with a family type of another object.
The family type that is selected is one of the GMA inside the main GMA, which is odd.
Interestingly the type that replaced the family is also a Generic model adaptive (GMA). Now we take this Family and try to use Speckle on it an receive it in a clean template file.
It seems that there is a change in behavior. The element were again replaced with another type but speckle did place the elements in the model, which is an upgrade from our previous test.
Lets test it again but this time we pre load the main family of the wanted items, this is one of the GMA’s inside the main GMA family.
The family was not replaced and the element were placed by Speckle. But the preview and the created element don’t look similar at all. This can be explained. The family that was used is a Generic model adaptive (GMA). If its placed without the host family it will take its neutral dimensions. That is probably what happened here.
Now we need to find a way to send the main Generic model adaptive (GMA) and be able to receive them in another project. We select all the element of the same GMA type and send it to Speckle. Than we edit the family in the main model. We load it into the project but choose another empty project as place to load. This will be our new model. We place the element and it seems to be correct. Lets see if speckle is able to do the same as we did manually.
Speckle again did not find the needed type of the family. Wich is strange because we have it loaded into the project. We have placed it in the project and still it was unable to find it.
Lets give it one last test. We take all the individual components from the main Generic model adaptive (GMA). This is a total of 3 elements and send them all individually to speckle. Then we try to receive it into the new project.
The previous seems fine.
Two of the elements are placed inside eachother and have changed in measurements(left side). Another component has also changed measurements but ended up seperated from the others(right side). It seems like we ran into the same issue as before. Because the host/main family is lost the GMA’s that were inside it take their neutral form/dimensions and don’t look similar to the wanted/previous elements. The change in location is odd and I can not explain it.
End questions and remarks
What is going wrong here?
Why does the main GMA not get received correctly in Revit from Speckle?
It does work when I use my own simply created GMA with 3 GMA’s inside it but when I used this GMA from a third party it does not work? What could cause such an error?
At first I thought the “shared” function was the trouble maker, but having made my own GMA with all components being shared I could still use Speckle just fine.
