I’ve been using the Speckle Panel on Rhino, and I find the textbox a bit hard to use. Maybe the background can be white? Or, text can be white (or speckle blue?)
The main issue is that after a commit, the text box does not clear. And I keep forgetting to clear the nearly invisible text (previous commit message) before typing the new one.
Is there some setting to change this? Or this needs to be changed on your(developer) side?
TIA
Kaushik LS
Chennai, IN
