Hello everyone!
I am new to Speckle and really excited about it. Currently, I am still playing around with this tutorial. But when I try to receive the model inside Rhino, the Speckle stream shows the following warning,
Failed to bake object ac12ed56a7ce068fec123ead84670e88 of type Objects.Geometry.Mesh: ON_Mesh.m_F[218] has degenerate double precision vertex locations.
Any idea how to fix it? FYI, I use Rhino 7 and Revit 2021.
Hi @fauzanalfi!
Welcome to the community! If you feel like it, you can Introduce yourself 🙆 to everyone here
That sounds like some nasty error… I’m going to check on my side to see if I can reproduce it, but meanwhile:
- could you let us know what version of Speckle Manager and the Revit and Rhino connectors you have installed?
- What units are you using in your Revit project? and in Rhino?
Thanks for reporting this!
Hi @AlanRynne!
Thanks for your prompt response.
I am using:
- Speckle Manager v2.1.5
- SpeckleConnectorRhino v.2.2.2.7060
- SpeckleConnectorRevit v.2.2.2.7064
Both Revit and Rhino projects are using metric units (meter and millimeter). Actually, I didn’t change any unit setting in the Revit and Rhino files provided by the tutorial.
Great! Thanks for that!
We’ll keep you posted when we I get any updates on this
