Seeing as JSwan is out of support, and Speckle loads its own version of Newtonsoft into GH, it might be a good “two birds, one stone” thing to have XML > Speckle and JSON > Speckle nodes.
I whipped up an example that uses some of our internal patterns that worked, but I think it belongs in the speckle extension so we don’t get dependency hell. I’d contribute it but I know the converters are getting a rejig, so currently it’s just a suggestion - POC worked pretty well!
jonathon
(Jonathon)
23 July 2024 06:54
2
Is your M2S node a simple c# wrapper?
It just steps through any JSON file provided and converts it all to Base - I’ll drop it as a snippet below as its fairly simple:
public static class Converters
static Base GetBase(JToken token)
Base root;
if (token.Type == JTokenType.Object)
root = new Base();
foreach (JProperty property in token.Children<JProperty>())
string propertyName = property.Name;
if (property.Value.Type == JTokenType.Object || property.Value.Type == JTokenType.Array)
Base intermediateBase = GetBase(property.Value);
if (intermediateBase is Collection c)
root[propertyName] = c;
else
root[propertyName] = intermediateBase;
else
root[propertyName] = property.Value.ToObject<object>();
else if (token.Type == JTokenType.Array)
Collection g = new Speckle.Core.Models.Collection();
foreach (JToken item in token.Children())
g.elements.Add(GetBase(item));
root = g;
else
//edge case for things like arrays of strings
root = new Base();
switch (token.Type)
case JTokenType.String:
root["string"] = (string?)token ?? "";
break;
case JTokenType.Boolean:
root["bool"] = (bool)token;
break;
case JTokenType.Integer:
root["int"] = (int)token;
break;
case JTokenType.Float:
root["float"] = (double)token;
break;
case JTokenType.None:
root["null"] = null;
break;
default:
root["object"] = token.ToObject<object>();
break;
return root;
public static Base FromJSON(this Stream stream)
using JsonTextReader reader = new(new StreamReader(stream));
return GetBase(JObject.Load(reader));
jonathon
(Jonathon)
24 July 2024 07:19
4
Contributions are always welcome, GH isn’t on the critical path of connector refactoring right now.
All good I’ll keep this one on the back burner in that case!
