Error when trying to upload an ifc to speckle
Hi.
I got this error when trying to upload an ifc to speckle.
Please help me fix this problem.
IFC upload error
@Joachim_Ovrid does this error happen repeatedly with the same file?
Clearly IFCjs is choking in this instance, but can you attempt the same file again and repeat it so we can check if it was a hiccup or a choke?
@jonathon
The same error with the same file every time.
When I try to link it inside revit it gave me a warning that the ifc was a ifc 4 file. Maybe that is the problem.
I can upload it again for sure.
can you share it with me?
Hi.
The ifc is now emailed to you by email
