Error when trying to open Revit connector
Looking for some help running into an error when trying to open Revit Connector in 2023
Error says:
Revit encountered a Method not found:
'Serilog.LoggerConfiguration
Serilog.Configuration.LoggerSinkConfiguration.Conditional(S…System.Action’1<Serilog.Configuration.LoggerSinkConfigurat…
I did just update to version 2.17.0 this morning. Thanks for any help that can be shared.
Revit PNidmodeler Add in needed to be disabled then it worked.
Thanks for the update - to confirm it is the P&ID Modeler for Revit that was causing difficulty.
It is a zoo when handling different dependencies - but we should all see what we can do to avoid conflicts.
You detail will help us pinpoint where the conflict lies
:pray:t2:
Ya that’s correct, I had the same error a few months back but had forgotten the solution. Going back through my messages on Speckle I saw someone had mentioned to me earlier it was like an add-in and to go through and disable them one by one to figure it out. I found that it was the P&ID Modeler for Revit.
