Error sending from Advance Steel
Send Error!
Speckle.core.kitsException – Failed to load converter for app AdvanceSteel2023:
Converter for AdvanceSteelo2023 was not found in kit C:\users….
Can someone tell me what I did wrong during installation that the corresponding file is not installed.
Speckle Status: All checks passing !
Speckles Version: Speckle for Advance Steel v.2.20.2.16251
I have elevated your trust settings on the forum, so feel free to upload them again. In the meantime, a missing converter error typically comes from having different versions of the Speckle connector across different host applications; do you think this could be the case?
Is there any way I can check this?
I can’t find a converter for AdvanceSteel in the …Speckle\Kits\Objects folder.
The converter for Revit is there.
I’ve checked the installer scripts - and it should be available - suggest uninstall and reinstall Advanced Steel connector from Manager and report back
I tried to remove the installed connector 2.20.2 in the manager.
Somthing went wrong
Connector für AdvanceSteel was not removed.
