when i load room value parameters data to get visualize screen. the below error message comes.
please suggest the way forward.
Are there other data sources in your workbook?
i don’t know, now its working fine. but how do i get colors to the 3d view. at present i can see only one color to entire project. which is very difficult to understand.
plz refer below image
thank you, its quite impressive.
i have one doubt. in the query edition the rooms/level names/area/number are counting double, i don’t know why. due to this every data counting in double in the reports. refer below two snapshots. from power bi and revit .
from power bi
Are you performing data joins that could be accountable or is this entirely the stream coming from Speckle? It would be very odd to see two objects with identical ids coming from the data connector
i m not performing any data joints, it’s entirely comes from steam speckle.
i am facing two issues,
when data comes correctly then 3d view is not appearing in power bi.
when 3d view appearing then data is shows double in power bi.
could u plz share the video / snapshot, how to export from revit and when i load in power bi, both data & 3d to be appearing correctly.
is extraction from revie wrong?
can i send the URL link
