Hi @thekaushikls! Thanks for the patience and thorough report - these things can be frustrating so kudos for making the extra step to let us know about this.
Personally, I’m unaware of what can cause this - looks like some potential UI dependency… Pinging @teocomi for extra eyes on this.
What could for sure help - especially if it works on your wife 's PC (kudos to her too!) is a list of installed plugins. Are they the same on both computers, and if not, what’s different on yours?
There can be some crossed wires in the dependencies…
As Dim says, it seems like a conflict with another plugin.
Could you try deactivating other Rhino plugins you have installed?
To narrow down your search, you could see if there are other folders inside %appdata%\McNeel\Rhinoceros\7.0\Plug-ins\ that contain a file called Splat.dll:
Thank you for the quick response(s). I do not have any Splat.dll file. But, I did narrow down the issue to be a plugin from work. I disabled that, and everything is fine. Great!
Nice! If you could let us know/drop a screenshot in here of the plugin’s dll dependencies, we could keep an eye out and see if there’s a way to avoid this conflict in the future.
