Error from Excel to Revit - New values of Revit schedule does not appear
Good afternoon,
I’m trying to use Speckle from Revit to Excel and back to Revit.
From Revit to Excel everything works perfectly, but from Excel to Revit, the plugin tells me that it correctly send and receive, but I don’t see those “new” values appearing in Revit schedule.
The procedure that I followed is the same described on the tutorial. I’m using Revit 2023 and Excel is updated.
Thank you in advance!!!
Are you changing values that would be Instance-based parameter values?
It’s shared parametrs, in particular I put two text parameters based on istance and one based on type.
But no one of those appear. I think that some setting may be wrong…
