Erro message: Send Cancellation
I’m new to speckle. trying to paly around and started with exporting navisworks model, unfortunately, I’m running into the error shown in the attached snip. I tried with different selection settings with no success.
Thanks for the report @Mo2023, I’ll take a look because theoretically there is only one code path that leads to that warning - sending with Everything mode …. But I see you have a selection set.
My hunch of what happened is that you may have tried Everything mode, encountered the warning then set Selection mode which should have worked, but the UI held a setting that didn’t update.
Let me try and replicate to that hunch and I’ll get back to you — In the meantime, if you start a fresh Send starting from the Projects list and not from the UI panel shared above and see if that helps.
Hi Jonathon,
Thanks for your response, that worked and the model seems to be uploaded successfully, despite not being able to navigate it on the web due to perhaps the large number of objects contained.
However, I’m encountering another issue with power bi connector as shown here, any solution?
Cheers,
Have you set the projects as “link shared” access?
Yes, I have, though still the issue persists
