We are thrilled to announce the winners of our #beyondthespeckleverse hackathon. This event showcased a remarkable spread of ideas, implementations, and problem-solving approaches. Participants tackled diverse challenges, from streamlining workflows and improving model quality to leveraging AI and advancing future construction methods. The common themes among the projects were innovation, collaboration, and a commitment to enhancing the AEC industry. Congratulations to all participants for their creativity and hard work!
The Devpost Project gallery now has the winners flagged and all our participants have been notified!
★ Most Impressive Low-Code/No-Code Implementation: Kai Tak MGM JV
An approach for a tunnel path solution based on geological and GIS data. Speckle is used throughout the process to exchange data between different software, eventually feeding the tunnel algorithm.
★ Popular Vote Winner: AI2Speckle: Textures Search
AI2Speckle: Textures Search imports 3D models into Speckle, uses AI to generate renderings, extracts material patches from the renderings with AI, and reintegrates them back into the model.
★ Most Impressive Use Of Business Intelligence: What.If.Architect.
What if I remove this column? “Nothing is fixed until it is built.” This project addresses communication within the structural and architectural design process, tackling the complexity and conflicting concepts in the AEC industry.
★ Most Impressive Project Pulse: Speckle Orchestrate & Coordinate
Streamline workflows with Speckle Coordinate and Orchestrate using n8n! Connect to other APIs, manage streams, branches, and users, trigger webhooks. User-friendly GUI for even easier automation.
Our project pushes 3D scans done with smartphone LiDAR tech to Speckle using a custom Python connector. Once in Speckle, you can use Dynamo to convert the scans into Revit objects.
★ Most Impressive Use Of Automate: Effortless model quality check with Maple
With Maple, you can easily write tests for your models, validate the elements have the correct quantities, and run tests inside Speckle Automate to ensure your model is up to standards.
@community, thank you for making the #beyondthespeckleverse hackathon a huge success! Your enthusiasm, creativity, and commitment to innovation have been truly inspiring. Each project demonstrated the power of collaboration and the potential of open digital delivery in the AEC industry.
Take another look at the project gallery for inspiration on what is possible with Speckle and your imagination and skills.
Let’s continue to support each other and push the boundaries of what we can achieve together. We can’t wait to see what you’ll create next!
