Hello.
I’ve uploaded my Revit model to https://latest.speckle.system, which allows me to develop a solution via Speckle’s Viewer API with codesandbox.io.
After installing the connector on Excel, I realize that I do not see my model, even when I try to add an ID, it does not work. I realize that the Excel connector uses the server located at https://app.speckle.systems/...donc, not the same one…Is this normal?
I’ve founded, I need to change server address…
Sorry
You can delete the post if you don’t think it’s useful…
