Deleting objects in Revit and receiving it in sketchup doesn’t work
Tried creating, moving, and deleting objects in revit and receiving it in sketchup. All operations work fine except for deleting objects in revit. When I delete an object in Revit and send it to Speckle, it removes the object in the online viewer but doesn’t when you receive it in sketchup (May it be a wall or a furniture, any object)
Step 1: Created walls and a component in Revit
Step 2: 3D in online viewer (works fine)
Step 3: Receive it in Sketchup
Step 4: Delete a wall and the component in revit
Step 5: How it looks in the online viewer
Step 6: Receive it in sketchup
As you can see in Step 6, the wall was only detached from the rest of the walls, but not deleted. Also the component was still there in sketchup.
Kindly need help on this, thank you!
