Before diving into this issue, could you clarify what you’re aiming to achieve? I ask because we’re currently migrating Speckle away from the Avalonia framework. If you intended to contribute to the Mapper within that context, it’s worth noting that we probably won’t be able to adopt those changes due to this transition.
From a beginner’s perspective, I’d start using the SDK to interface with the API and make queries for the Speckle data. The DUI project is the retiring method of creating Connectors for host applications.
If that is what you want to achieve, we can address this IDE issue with you, but it’s not a starting point with Speckle that I would recommend.
Which projects are you unable to build?
What version of visual studio are you running? have you tried updating to the latest?
For the speckle-sharp repo, we recommend you use version 8 of the .NET SDK (included with Visual Studio 2022 17.9.x or greater), older versions will not be able to build all projects.
