I am working with the PowerBI Visualization. I have some geometry that came from Revit and I am trying to color it in the visualization based on a parameter value. I have assigned that parameter to Color By field, but it isn’t changing. I have also tried to add a formula to override the color. This didn’t work either. Is this possible? The objects are Revit Furniture Families if that makes a difference.
In case it makes a difference, instead of using the Count of the Level.Number.value can you use the Level.Number.value the conditional formatting value to the 3d visual?
