Panned surface in Viewer is not following the cursor rather it is going the opposite direction.
How to change its behaviour such that it follows the cursor when panned.
Is there an option for this, i couldn’t find in the documentation.
Thanks,
Thanks,
From the video I see that the effective action that you want to flip direction in the viewer is the orbiting action,even though in a 360 viewer it would be called “panning”. Flipping orbiting direction is easy, and can be done via CameraController’s options
cameraController.options = { orbitSensitivity: -1 };
For better clarity we will add explicit options for flipping action axes in a future release
I’ve updated the live example I made for you a while ago that simulates a 360 viewer to have the orbiting flipped.
Cheers
Thanks Alex, this is perfect.
Hey Alex, another question. i want to keep both views in sync
So when i pan around on image i get a yaw pitch value,then i use yawpitch to cartesian converter, it returns target value
i am passing this target value and original(calculated at initialisation of the viewer) position of the camera in
fromPositionAndTarget
there seems to be a shakiness when transitioning. attached video for reference.
i am thinking its because i am setting both the position and target everytime. can you suggest something for this.
I suggest you try setCameraView from the CameraController extension by passing it a PolarView where you can directly use your pitch and yaw values. Do note that both azimuth and polar are expected to be deltas and not absolute values.
Using fromPositionAndTarget should also work, but in your particular case position stays the same, and only the direction changes, as you are rotating in place. I could help you more if you made a live example where the problem can be observed. You can use stackblitz like I did with the previous live examples I shared with you
Cheers
Hey Alex, spent some time on making an example.
i’ve tried using polar coordinates. its kinda working but it always pans to the right even if i pan left
Example
updateCameraPosition function is where i use setCameraView.
view has the current position(yaw,pitch) from SingleViewer.
I’ve made a few small changes to your live example:
PolarView, it is treated as a delta, not absolute values. I changed this and now deltas are computed for pitch and yawPolarView expects it’s azimuth and polar values in radians, that’;s why I’m multiplying the values with 1/Math.PI
Cheers
Thanks @alex .
After making the uniform delta value everything is aligned and synced.
Hey @alex
it’s been a while. thanks for all the help, recently shipped the feature to production. ![]()
now am going around other way to sync the image with speckle’s camera position, target.
so basically last time what we did was get the yaw, pitch from panning around in image,
this time we’re panning around in model and want to keep the image in sync.
is there a method in camera controller which could get me these values or do i have to convert cartesian to yaw,pitch values.
There is an easy way for you to get polar coordinates by reading the active controls from camera controller. This will give you an abstract SpeckleControls type, but you can assume it’s the explicit SmoothOrbitControls implementation which has a public spherical property which will give you polar coordinates. Do note how the angles wrap, as it might be different than the ones you are using for the image. However the SmoothOrbitControls type is currently not being exported by the viewer library so you’ll have to “cheat”
If you don’t want to hurt typescript’s feelings with the above solution you can still use the active controls from the camera controller as the abstract SpeckleControls and just use it’s getPosition (which is the camera position) and getTarget (which is point in space where the camera is looking) to compute the polar coordinates.
Cheers
