Cant send geometry from Rhino
I am getting an error when i try to send geometry from Rhino to speckle.xyz
Object reference not set to an instance of an object.
   at SpeckleRhino.ConnectorBindingsRhino.<SendStream>d__29.MoveNext() in C:\Users\circleci\project\ConnectorRhino\ConnectorRhino\ConnectorRhinoShared\UI\ConnectorBindingsRhino.cs:line 0
--- End of stack trace from previous location where exception was thrown ---
   at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
   at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
   at Speckle.DesktopUI.Streams.StreamsRepository.<ConvertAndSend>d__2.MoveNext() in C:\Users\circleci\project\DesktopUI\DesktopUI\Streams\StreamsRepository.cs:line 22
Hey @honorgorge ,
That is a very old UI. What version of Rhino connector are you using? Can you try updating your Rhino connector via Manager?
It should look like this👇:
Ah yes i also tried to update it and got an error.
I think i must update it manually, i downloaded latest rhino connector but now i dont know what to do with these files
You need to close any application that has a Speckle connector. If Revit/Autocad ,or any of the applications we have a connector for, is open, try closing them and reinstalling the connectors.
Okay now it perfectly works. sorry for disturbing with this small issue and thanks for the support :slight_smile:
No worries. Great to hear that it worked out for you. Let us know if you have any other issues. Don’t forget to check out CAD2BIM mapping tool. It’s early alpha and your feedback really helps us.
:rose:
