Recently updated my self-hosted server (see here - Manual server deployment issue - #12 by imanwarsame).
Now however, I can’t receive or send streams in Grasshopper
And I also can’t receive streams using the viewer API getting this error
Access to fetch at 'https://speckle-test.ramboll.com/api/getobjects/16b6b8eeea' from origin 'http://localhost:5173' has been blocked by CORS policy: No 'Access-Control-Allow-Origin' header is present on the requested resource. If an opaque response serves your needs, set the request's mode to 'no-cors' to fetch the resource with CORS disabled.
This wasn’t happening before updating the server and for some reason it works for one stream, but not the others
