Can't Receive Objects/info From Revit In Rhino
Hello all.
I’ve updated the Rhino, Grasshopper and Revit connector to the latest version (20.2 atm) but I’m having issues receiving info from Revit into Rhino (I’m using the latest version of Rhino 8)
That’s the message I get. So far I can I only make it work with the connector version 17.1.
Thanks in advance
Please can you share with me a log file from %appdata%/Speckle/Logs/rhinoRhino8 and I’ll investigate.
@DavorPantoja could you confirm the dotnet runtime you are using in Rhino8 and also the specific version of Rhino 8 e.g 8.1? 8.3? or 8.9 etc?
Hi, yes I’m running dot net Framework. (It works with the connector 17.1)
The Rhino version is Rhino 8, 8.10.24228.13001
Thanks !
Thank you Jedd
SpeckleCoreLog20240904.txt (68.6 KB)
