I’m new user of Speckle. I tried to connect Speckle into Power BI but having problems where it said that “We cannot apply field access to the type Null”. My model is from Navisworks and I’ve used email address the same as Microsoft email. i dont know what Im missing.
I managed to solve this problem by creating a token key on the Speckle website and then, instead of selecting the first option that appears, I selected the top option and inserted the token. It worked for me. (Note: I am just a user, there might be better solutions).
@Anisa_Liyana welcome to Speckle community.
@Francisco111 is referring to Personal Access Tokens that you can access from your account
how to solve this issue ? please explain step by step…
Hey @DHINESH_Raj1,
Welcome to Speckle!
What Power BI connector version are you using? What is your project URL?
If you haven’t done this already, download and install the Speckle Manager from here.
Install Power BI connector from the Speckle Manager. This will create two folders under \Documents\Power BI Desktop.
Go to your Project Settings and make sure to set your project to Link Sharable or Discoverable. If your project is set to Private is not going to work.
Follow the configuration settings Configuration | Speckle Docs
Try to receive your project again.
Hi @here,
We have a new release of the Power BI connector that would hopefully resolve this issue without requiring a token. When you get a chance, could you please download the latest Power BI connector from here and let us know if it works for you?
Thank you!
