Where streams do not originate from Revit or the SpeckleBIM gh components, is there a mechanism or protocol whereby arbitrary data properties on a Base object would be instantiated as data parameters when reading this into Revit?
I suppose that is two questions…
- Can RevitConnector infer arbitrary data as parameters?
or, if not, - What extra steps are necessary to declare a Properties Base object as being data parameters parseable by Revit?
