The ‘Export’ command in Navisworks (Simulate 2022) uses the shortcut Ctrl+Shift+S, same as the speckle connector.
When using the shortcut, the speckle connector opens instead of the export file browser window.
I expect the speckle connector should have a shortcut that is not currently used by Navisworks so there isn’t a conflict.
I have uninstalled the speckle connector for now as I’m using the shortcut for some specific automations with PyWinAuto but it would be ideal to be able to use both ![]()
