BLENDER PLUGIN - not shown
Hi
I can’t see the Speckle plugin when i press N in Blender although it does work for me in Revit. Any suggestions?
Which version of Blender are you on?
4.1
No other plugins are installed
In Blender go to Menu > Edit > Settings > AddOns,
check that “Show only activated add-ons” is deactivated,
Set Filter to “Scene”,
check if Speckle AddOn is activated (checkbox).
If not - activate it and check the “N” Palette for Speckle Tab entry again.
Zoomer’s suggestion works. The problem in my case was that Blender detected that the Speckle plug-in was a WIP (I assume, meaning work in progress, or Beta) and doesn’t activate it automatically and when you have “…Activated Only…” checked, it will not appear.
I had this problem also on both CC4 and iClone 8. What you have to do
  1. Go to your Reallusion HUD and uninstall both CC4 and iClone 8, Blender plugins
  2. Then reinstall both one by one - inside your Reallusion HUD
  3. Then reinstall the updated Blender cc-tool 2-32 plugin zip file into Blender.I’m using 4.5 LTS.
    This should work!
