Thank you for seeking help! Our friendly community is here to assist you.
would like to use Speckle in Blender 4.1 or 4.0. but both are not working
got the message: Python: Traceback (most recent call last): File "C:\Users\u4XXXXX\AppData\Roaming\Blender Foundation\Blender\4.1\scripts\addons\bpy_speckle\operators\users.py", line 103, in execute raise Exception("Zero valid user accounts were found, please ensure account is valid and the server is running") Exception: Zero valid user accounts were found, please ensure account is valid and the server is running
Steps I tried.
deleted the existing add-In
installed lates one is now on 2.19.1
connected the “manager” with online library, have some projects and items there, all fine
If you’re still having problems after performing this step.
You could try disabling any VPNs or try a different network.
Some corporate networks/VPNs may be configured to restrict access to the internet.
Please let us know if any of these suggestions work for you, I can assist further if needed.
thanks for mentioning, maybe VPN is the key. most servisec are fine working with VPN, assigning/Log in worked, I can see that the manager is online. but in Blender it doesnt work. will test it on monday, sorry its weekend now
You should find that a more informative log is printed to console. Please can you copy/screenshot the report and post it here. This will help me understand the precise problem.
Thanks for your patience.
If you have a similar problem, and have followed the same steps as I previously mentioned (ensuring your account is added in Manager, tried turning off VPNs, trying another network, etc.)
Then perhaps you could also follow the instructions above, and send me the console output.
Hello, here is the message first after opening Blender
Read prefs: "C:\Users\phmclean\AppData\Roaming\Blender Foundation\Blender\4.1\config\userpref.blend"
Starting module dependency installation
C:\Program Files\Blender Foundation\Blender 4.1\4.1\python\bin\python.exe
C:\Program Files\Blender Foundation\Blender 4.1\4.1\python\Lib\site-packages\_distutils_hack\__init__.py:33: UserWarning: Setuptools is replacing distutils.
warnings.warn("Setuptools is replacing distutils.")
Using connector installation path C:\Users\phmclean\AppData\Roaming\Speckle\connector_installations\Blender 4.1
Installing Speckle dependencies to C:\Users\phmclean\AppData\Roaming\Speckle\connector_installations\Blender 4.1
Successfully found dependencies
Then I did refresh on Speckle plug-in
SpeckleBlender: Loading users...
SpeckleBlender: Failed to authenticate user account [email protected] with server https://app.speckle.systems: SpeckleException: Failed to execute the GraphQL active_user request. Inner exception: HTTPSConnectionPool(host='app.speckle.systems', port=443): Max retries exceeded with url: /graphql (Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1006)')))
SpeckleBlender: Authenticated 0/1 accounts
File "C:\Users\phmclean\AppData\Roaming\Blender Foundation\Blender\4.1\scripts\addons\bpy_speckle\operators\users.py", line 103, in execute
Erreur: Python : Traceback (most recent call last):
@HeinrichBoldtGetinge When you get the time,
I’d appreciate if you can send me your console logs too, as you may be seeing a different problem to @McLean
Read prefs: "C:\Users\u4014125\AppData\Roaming\Blender Foundation\Blender\4.1\config\userpref.blend"
register_class(...):
Info: Registering operator class: 'OBJECT_OT_AlignOperator', bl_idname 'object.align' has been registered before, unregistering previous
Using connector installation path C:\Users\u4014125\AppData\Roaming\Speckle\connector_installations\Blender 4.1
Installing Speckle dependencies to C:\Users\u4014125\AppData\Roaming\Speckle\connector_installations\Blender 4.1
File "C:\Users\u4014125\AppData\Roaming\Blender Foundation\Blender\4.1\scripts\addons\bpy_speckle\operators\users.py", line 103, in execute
Error: Python: Traceback (most recent call last):
this is what I get,
had to activate the Plug-In, tried to reinstall the new one.
from company IT we have a new Firewall-Application since mid of last week. maybe this might effect.
At least the idea with mobile hotspot does not help.
same issue.
I have another device, thought about run installation for Blender and Speckle there as well, but remembered about McLean, that he has same issue as me.
Thanks for your patience,
Our team will take a look next week to see if we can provide a solution that meets our security requirements.
In the mean time, you may consider contacting your IT department.
