In theory though, this is looking very cool when federated - Viewer - Chris’ Second Project - Speckle
@jonathon and co, any thoughts on this? I could just be configuring my C# incorrectly but it’d be good to be able to confirm. My expectation based on the docs is creating a commit + context view should make them show up in the UI.
It does look like you are correct, the view above should have a “View Results” button for a generated context view:
I’ll look into it
It looks as though in a recent UI update the image editor for a function has now been shrunk
I also can no longer make the image full the whole space, so there is padding between the image and rounded border which I can’t remove
I should never have called your dedication to the brand into question!!
I’ve just pushed a fix for the double status report issue @sanchez, @chris.welch.
Its a forward only fix, so existing double reports wont go away, but on new version push to models, we reset the statuses and once automations completed, you should only see correct result status.
Could you confirm, that its fixed on your models too?
Thanks ![]()
Hi Gergő, it’s working properly on both on old and new models for me. It looks like some of the front end is still not responding to the job succeeding however:
Front end bug: the first time I created a new automation in a while, “that’s it, you’ve loaded everything!” popped up before any function in the library had loaded. I couldn’t reproduce this a second time shortly after - it just showed a loading screen and then all the functions as you’d expect.
Hey @chris.welch
we sort of know, that there are a few of these subscription related issues in the current setup.
This one we’re probably only going to fix in the automate 1.0 release, since we’re changing most of the underlying api with that effort.
But do keep there reports coming.
Hey @jonathon any thoughts on this? I’m keen to progress the prototype next week, so it’d be good to know if a fix was on the way.
@jonathon I’ve logged a PR to fix this issue: Brings CreateNewVersionInProject up to parity with SpeckePy by secretlyagoblin · Pull Request #3298 · specklesystems/speckle-sharp (github.com)
Thanks for contributing this @chris.welch - I’ve brought it to the attention of the Connectors team.
